QUOTE(mikez @ May 27 2006, 07:31 AM)
Typical bolt stripping area. Easy fix is to find another tail piece....
OR....fix it by inserting a sleeve....best to pull it, drill it, tap it and put a heli coil in it. I did one that way once and it was fine for years.
The BEST way...I've heard...is to weld it up and drill and retap...never done it.
"Weld" it?!!!!! Welding mag alloy requires scrupulous and intensive cleaning off the car, mag welding equipment, and repair of the bore after you're done. A helicoil is difinitely the method of choice, and it can be done with the cover still installed. In fact, if the tail end of car is jacked up far enough, it can be done without losing more than a few drops of gear oil. Just gotta have a steady hand and a good eye to keep the drill straight. The Cap'n, off for a shopping trip in the boneyard. Y'all play nice!
