QUOTE(1970 Neun vierzehn @ May 27 2006, 10:46 AM)
What is the correct finish on the lug bolts for Pedrini, Mahle and Fuchs alloy wheels? Silver paint? Black paint? Plastic caps
And, of course, everytime you remove the wheels and then remount them, you scuff the finish on the bolts once again. How were they finished originally, and how's an easy way to maintain a nice finish on them today? My '70 was originally delivered with 4.5" steelies w/hub caps AND aluminum trim rings
. Since my Pedrinis were fitted 20 years ago, I have no idea how the bolts were finished when new.
Mecedes and Audi both use Dacromet on their wheel bolts..Google Dacromet..
IF you do not mind a 17mm head on the long wheel bolts for the alloy wheels,,,
(and the head is flat) the Audi one will work better than that $45 junk ebay set that is chromed...Around 3.50 each I have a source...
The Ebay ones>Threads are off pitch a bit and can possibly strip your rotors......#2= the 'radius' is
way off on the dome..And can back out!!!!Beware of the ebay cheapies!!
My 73 2.0's on my Fuchs were original to the car...Had the Dacromet type
finish to them...Green Production paint stripe on them..
And the black caps as covers...
I had my originals 'Clear' Zinc coated...(silver)...They came out horrible...
Even a bit of a greenish tint to them....
Dacromet in my terms would be the best .....
on the bottom of my wheel bolts is stamped KX with the VW circle symbol..
I have a set of new ones from Porsche..That have close to a chrome finish
on them..(not as wonderfully machined as the originals) and no markings...
Does anybody else have a new set From Porsche out there???
Now on the early wheels..
I have pulled black and silver off of various years...Shorter and longer...
Seemed the star (X) 74 thru 76 steelies were a bit longer than the older steelies..
ALL had VW stamped on them.....
