Hi,
I've got a 72 1.7L and it's just finished being restored, now I have a problem with it running. It is very hard to start up and doesn't like to idle cold, now once it has been warmed up by running it around the block a few times it runs better and idles not too bad
now when running it seems to lag and not want to accelerate as quickly as it should. It feels like it's plateauing at around 2500-3000rpm and after that it takes off again through 4-5000rpm
it is also not giving me full throttle, at 3/4 of the way down the pedal is when it feels the best. if i push the pedal down any further it feels like it is bogging out. it also bogs out when it is warming up and sometimes backfires
I've gone through the newly rebuilt motor and everything seems fine, at first i found it was a broken hammer within the TPS and that has been since replaced. The MPS looks like it's been opened up and F-ed with. any suggestions as to what to do?
Thank you,
-Mike
