DNHunt
Sep 27 2003, 07:28 AM
Here is a picture of the VR sensor mounted to the back of the inner cooling shroud. It fits between the shroud and the oil cooler, oil filter.
DNHunt
Sep 27 2003, 07:32 AM
I routed in a stainless steel gusset with a track so that the sensor position can be adjusted. Stainless carriage bolts anchor it
rhodyguy
hey, lets go get breakfast. jeannes still snoozin. like i said last night im way impressed. just visualizing your setup would have me gulping tylenols.
kevin
Bleyseng
Sep 27 2003, 07:33 AM
Gawd you two are up early!
Geoff
DNHunt
Sep 27 2003, 07:35 AM
I can only hope that the first time I adjust it I'll get it right. Getting tools in there is going to be a bitch. Here is the shroud and the sensor mocked up to the front of the engine
DNHunt
Sep 27 2003, 07:36 AM
another
Dave
DNHunt
Sep 27 2003, 07:41 AM
Kevin,
I'd love to get breakfast but I gotta help with the kids. Betsy's trying really hard to show some interest and encouragement right now. I gotta help in return. See ya later this morning.
Dave
rhodyguy
Sep 27 2003, 07:42 AM
if your cars not done and you're typing i'm going to have a field day.
kelvin
Brad Roberts
Sep 27 2003, 08:59 AM
Dave... your going to have to notch the fan shroud so you can get tools in there.
Also.. how to do you move the sensor closer or farther away ?? Shouldnt it have a .60 gap or something ??
B
Katmanken
Sep 27 2003, 10:28 AM
Ah, the eternal search for a way to sense crank position on one of these engines!
I was screwing around on my Vanagon engine (T5)and found this funky 3 prong connector with a wire running under the EFI to a hole in the engine case next to the flywheel. Didn't have a clue what it did as it wasn't connected to anything.
Looked in the manual and found that it was a VW TDC sensor that senses the flywheel position for tuneup procedures. From the pics of the flywheel, it seems to sense two small holes or magnets in the flywheel (pic too small to tell)
What this means is there are VW parts available that can sense the flywheel and can accomodate the longitudinal movement of the flywheel/crank (.003-.006) and still sense. I've been toying around with the idea of using a couple of these VW factory sensors and the flywheel to sense crank position. That area of the engine is fairly accessable for adjusting the sensors. Havn't looked to see if that location would be close enough to the axis of spin to provide a decent signal at high speed.
Ken
Bleyseng
Sep 27 2003, 10:35 AM
Dave, instead of carriage bolts look for a round head allen or torx bolt. That way you can adjust the timing/hall effect clearance from this side.
Geoff
DNHunt
Sep 28 2003, 05:57 AM
Thanks Geoff I'll try the other fasteners.
I can get to the nuts with the oil filter removed thats why I thought of the carriage bolts. I'm really hoping for set it once and go.
Brad, the clearance is 1 to 2 mm and the sensor is slotted to move fore and aft.
Dave
Brad Roberts
Sep 28 2003, 11:50 AM
I couldnt see the sensor slots..
Ken,
I have spoken of this in the past (when I first noticed the sensor on a VW block).. let us know what you find.
B
