I have a wiring problem that I can't figure out. Currently all the lights are working correctly, blinkers, driving, back up, brake. But, when I turn the ignition on, the blinker lights in the dash are on and the left rear driving and side marker lights are on. I have unplugged the gray/black wire, which turns the driving and side marker lights off, but the dash blinkers stayed on. When I drive the car and use the blinkers after a few turn signals, the blinker lights in the dash finally go out. They will blink when the turn indicator is turned on....
I checked the wiring in the left rear and it appears to be wired up correctly, so where do I check next? Obviously the rear lights are getting constant power from somewhere, I just don't know where to check next...
-- Rob
