jporsche914
May 28 2006, 07:03 PM
When i first bought my 72 1.7L 3 years ago it got about 15mpg. After putting an intake, 2.0L heat exchanger, triad west exhaust, and jacobs wires it is now getting about 19 around town and 26 on the highway. I fiqured that a fuel injected 80 hp car would get better gas milage even being old technology. My question to you guys is what kind of gas milage should i be getting?What should i do about making the gas milage better?
Thanks
James
Pat Garvey
May 28 2006, 07:11 PM
QUOTE(jporsche914 @ May 28 2006, 05:03 PM)
Thanks
James
Well, the last time I took my 72 on a long ride (Cincinnati to New Orleans), I averaged 36 mpg. Sound like you have a problem. Have you checked your vacuum lines? Are they hooked up properly? Could be timing, valve adjustment... an number of things - but it should do better than that! Opine, all gurus of techno-tune.
Dr Evil
May 28 2006, 07:14 PM
What elevation do you live at?
elwood-914
Wow, I was getting over 30MPG. But if I put my foot into it, I got around 28 to 29 MPG.
Is your car running rich? 15 MPG means something is up.
srb7f
Don't know exactly what I'm supposed to be getting, but I just recently got about 30 mpg out of my stock 2.0 on the highway. I have 195/60/15 tires without a re-calibrated speedo so it's a bit of an overshoot but it's gotta be in the neighborhood of 25-30. I think I did a bit better with the 1.8 engine I used to have, but I never really calculated it out.
jporsche914
May 28 2006, 07:22 PM
I live in colorado springs at 5500 feet. Timing is at 27 degrees and it getting about time for a valve adjustment but it not to loud. It seems to run good it does have a high idle problem which i have not been able to figure out could that cause this problem?
Allan
May 28 2006, 07:25 PM
"75 w/D-Jet w/elgin cam and euro pistons was getting right at 30 mpg around town if I drove it like I owned it.
26 - 28 if I dove it like I sole it.
Pretty good for a 25 year old car.
Lets see some of the 2007's beat that...
Joe Ricard
May 28 2006, 07:53 PM
my early 1.7L would get 32 MPG rolling 80 ish
my hopped up 2.0L has gotten 29 MPG @ 80 ish with carbs.
Brew
May 28 2006, 08:01 PM
High idle could be a vacuum leak, and that could be the contibuting factor.
Aaron Cox
May 28 2006, 08:07 PM
what size tires.....
jporsche914
May 28 2006, 08:10 PM
does any one have a vacuum diagram just so i can see if i am missing any? I have 205/40/17
smooth_eddy
May 28 2006, 08:27 PM
Pelican site has a good diagram. I will see if I can find it.
smooth_eddy
May 28 2006, 08:36 PM
JoeSharp
May 28 2006, 10:24 PM
Chump SUCKERS: Linda's car has gotten 49.16 and can do much better. Last weekend we had the car up to Lone Pine and on the way back Linda got 40.05 MPG up and down hills. She has gotten over 50. I changed the dist and the timing for this trip and I think it can be improved.
:PERMAGRIN: Joe
Hammy
May 28 2006, 10:30 PM
QUOTE(Joe Sharp @ May 28 2006, 09:24 PM)
:PERMAGRIN: Joe
what dizzy?
Brando
May 29 2006, 12:04 AM
Before I reduced my tire size, I was getting about 32mpg highway and 28mpg street when my 1.8 was poorly tuned. When well tuned and tall tires, it's between 35 and 37 highway, 30-32 street (mostly 5th).
Now with a well-tuned 1.8 and short tires, i don't care about mileage anymore... that's what the other car is for.
JoeSharp
May 29 2006, 06:32 AM
Zack: I changed from a 009 timed at 27 to a 010 timed at 30. Linda gained in the bottom and got more driveabilty but I think we lost a little on the gas mileage, I'm going to retard the timing to 28.
:PERMAGRIN: Joe
jporsche914
May 29 2006, 01:56 PM
Every once and a while when it is warm it will backfire and when it is cold it backfires alot. It happens when i am starting off it boggs down then starts to accelerate and then it backfires. Is this a rich problem how do i fix this?
Mueller
May 29 2006, 02:46 PM
your heavy wheel/tire combo is going to make the gas milage suffer a tad bit over a stock 15" Fuchs or Mahle combo....
what do you mean you installed an "intake"???
Cap'n Krusty
May 29 2006, 03:01 PM
I used to get 40-41 regularily in a bone stock 71. The Cap'n
TROJANMAN
May 29 2006, 03:31 PM
I get just about 28-30 mpg gallon, 35+ if i am eating beans........
TravisNeff
May 29 2006, 05:01 PM
Your high idle and backfires are telling me you have vacuum leaks, replace your hoses, and probably your intake manifold gaskets. Could be an exhaust leak as well. Any vacuum leaks and the engine will want to run rich.
