nycchef
May 29 2006, 11:02 AM
73 1.7 will not go past 4000rpms in any gear. changed vacuum hosese, fuel lines, timing, dwell, dizzy,cht, fuel tank. solve this for me and all this and more are yours.
Aaron Cox
May 29 2006, 11:03 AM
could be the fact that..........
IT'S a 1 . 7
sorry. no help....
AA
bondo
May 29 2006, 11:04 AM
Maybe you have a /6 tach?
brp914
May 29 2006, 11:14 AM
dang...gonna need some extra tall jack stands after all that.
does it idle ok? if so, measure intake vacuum. you should get atleast 14inch Hg. the idle air adj. screw should be nearly closed.
measure fuel pressure - should be around 28psi
good luck
boxstr
May 29 2006, 11:24 AM
Have you checked the rotor, could it be a rev limiter type to 4000rpm??
CCLIN400rpm
Allan
May 29 2006, 11:47 AM
You didn't mention valves...
rmital
May 29 2006, 11:51 AM
...great, I'm at work, depressed and hunger...thanks chef!
nycchef
May 29 2006, 12:11 PM
QUOTE(bondo @ May 29 2006, 09:04 AM)
don,t think so engine flies up to red line in nuetral and car juswt has no power. but will look into it thanks. come to nyc and the bbq is yours. rich
nycchef
May 29 2006, 12:13 PM
QUOTE(Headrage @ May 29 2006, 09:47 AM)
thats the next step. was about to do that sat when a blew out a brake line playing mario andretti. if you are right i'll start cooking thanks rich
Allan
May 29 2006, 12:32 PM
I would also check Craig's tip about the rotor...
brp914
May 29 2006, 12:41 PM
if your valves are so out of adjustment that it wont go past 4k, it wont idle well. if your valves are excessively loose, that engines gotta be making hellaciuos racket. and if excessively tight and driven that way for a while, your valve train is likely bbq'd along with those ribs.
is this a djet or carbs?
nbscooters
May 29 2006, 01:02 PM
check the trigger points.
So.Cal.914
May 29 2006, 06:01 PM
Something else that could cause that is a warn cam and followers. How many miles on the bottom end?
ptravnic
May 29 2006, 07:30 PM
Rich -
Not sure if you have checked out Paul Anders D-Jet troubleshooting/info pages...
http://members.rennlist.com/pbanders/-pt
jsteele22
May 30 2006, 09:51 AM
Q : What did you feed it ?
I wouldn't do much more than idle after a plate like that !
Good luck.
Dr. Roger
May 30 2006, 10:04 AM
i hope, for your sake, it's a timing issue.
if it is a crapped out cam i know that sir andy had a good used 1.7 for sale for a respectable price.
ejm
May 30 2006, 11:04 AM
Does the throttle open all the way?
John
May 30 2006, 11:54 AM
Does it break up at 4000 RPM real badly?
Swap out the coil for a known good one and see if that might be it.
ptravnic
May 30 2006, 12:44 PM
I don't know much about what a bad coil acts like but they're pretty cheap - maybe $30 or so.
Leo Imperial
May 30 2006, 11:32 PM
Update on the car....
Rusted brake line has been replaced.
Master is leaking like a ... lets just say big puddle
Gas pedal to be welded/repaired to avoid sticking - Wow no brakes and sticking throttle that was
Fuel pump connection was not conected it was arcing at the pump.
More on that tomorrow not sure it will fix the 4000 rpm thing
It's gonna run nice real soon
