QUOTE(lotus_65 @ May 29 2006, 11:01 AM)
thanks aaron. i would think that the red one connects to a wire in the tunnel then (i didn't buy my car with a pressure gauge installed... maybe the p.o. was going to, but didn't get around to it). i made a wanna-be 904 gauge so mebbe it'll hook up there!
the sender is mounted on a brass (?) extension and a 90 degree elbow, but i'm sure it was not grounded before. ground from one of the posts?
please do not use a solid brass extension. go buy a 1/8 npt grease gun hose from flaps...
the solid one willact as a lever, may snap, may break the case etc.....
go flexible hose.
pics of my setup are in my blog.
and if you ground the post, the light wont work....
you need to ground the housing (it originaly gets grounded from the threads in the case.... so if you use a hose.... you will need a metal "strap" to ground it)
