except...
the fuel pump. it's up front and the (red) power line runs along side the main harness above the tunnel and ends in the engine bay. i just can't find any power off the relay or anything!
the pump is high the o.p. one from the fi, and there's a loop in play. it was connected to run constantly, not to shut off. the fuse is present and was working fine previously.
should i just run power to it, or does it need to go into the harness somewhere?
