Aaron Cox
May 30 2006, 12:16 AM
friend posed the question, and i couldnt answer....
i believe i read boxsters fit... but not sure.
echocanyons
May 30 2006, 12:23 AM
I tried to fit steelies over the boxster monoblocks and they rubbed.
Jeroen
May 30 2006, 04:14 AM
boxster calipers will fit in a 15" fuchs
not 100% sure bout the 951 calipers though
Gary
May 30 2006, 07:40 AM
951's need 16's - at least up front.
horizontally-opposed
May 30 2006, 10:23 AM
Been meaning to try my 15-inch "deep sixes" over the front brakes on our Boxster. I hear the 15x6s and 15x7s will fit, but I'd like to see for myself -- and I'd suspect the backside of the "deep six" will interfere.
Anybody tried this? And, is it really worth it? Are the calipers lighter, is the 11.73-inch front rotor worth it with up to a ?-liter motor?
pete
Aaron Cox
May 30 2006, 10:30 AM
ive seen cookie cutters over boxsters before.....
Mueller
May 30 2006, 11:03 AM
QUOTE(horizontally-opposed @ May 30 2006, 09:23 AM)
pete
Pete,
for the 914/911 conversion, the rotor remains @ 11" diameter, you do however get the benifit of a lighter caliper and more pad area
Aaron Cox
May 30 2006, 11:06 AM
QUOTE(Mueller @ May 30 2006, 10:03 AM)
pete
Pete,
stock is 11"?
Mueller
May 30 2006, 11:14 AM
QUOTE(Aaron Cox @ May 30 2006, 10:06 AM)
stock is 11"?
yep, the stock /4 stuff is 11"...for the 911's, I think all the way up to '89 the front rotors are 11.10" diameter for the front (rear 911 rotors are 11.41" )
Jeroen
May 30 2006, 07:36 PM
for the Boxster or the 951 calipers, you need to use the Carrera 3.2 rotors
which are 282.5x24mm
check
http://www.pelicanparts.com/MotorCity/wmv/brakes.htm for more brake info
Aaron Cox
May 30 2006, 09:40 PM
QUOTE(Jeroen @ May 30 2006, 06:36 PM)
check
but 15" wheels will clear....?
Mueller
May 30 2006, 09:43 PM
QUOTE(Aaron Cox @ May 30 2006, 08:40 PM)
check
282.5mm = 11.12", the caliper does not have to be further away from the spindle axis for rotor clearance
930 turbo calipers fit under 15" rims.....
Aaron Cox
awesome....
and i guessthe adapter could have some offset in it, to put it closer to the center...
echocanyons
May 30 2006, 10:18 PM
I think but I can't remember for sure but I think that you will have to use SC rotors with the boxster monoblocks or the pads won't fit with the calipers.
Aaron Cox
May 30 2006, 10:19 PM
QUOTE(echocanyons @ May 30 2006, 09:18 PM)
....... you will have to use SC rotors with the boxster monoblocks or the pads wont for with the calipers.
clarify please?
echocanyons
May 30 2006, 10:42 PM
You would think I would know how to spell.
I meant to write won't fit. I initially purchased the carrera rotors for my conversion and I couldn't get the pads to fit over the rotors. After searching a bit and getting some feedback it seems the carrera rotors are about 2-4mm too thick.
I think this is the difference between the SC and the carerra rotors
I will find out for sure in a minute.
echocanyons
May 30 2006, 10:46 PM
linkJohn Jentz had the answer, now I am not sure if I only used the SC on the rears or all the way around.
echocanyons
May 30 2006, 10:53 PM
Definitely SC rotors all the way around
