Allan
May 30 2006, 08:02 PM
As alot of you know I've had a TON of problems with the six conversion I bought last year.
The biggest was a major head leak that lead to a complete tear down.
The big IF was that everywhere I turn, I hear the same thing over and over: It is impossible to get a 2.7 mag case engine to be leak free....
I'm not 100 percent sure but I think I have one.
After two (2) tear downs, I have put at least 1 a/x and 1000 miles on it since I got it back with ZERO motor leaks.
Should I give it some more miles or can I claim Victory over the mag case leak delimma?
fuch toy
May 30 2006, 08:07 PM
If done right...they won't leak....it's NOT a 4 banger....
DanT
May 30 2006, 08:10 PM
unfortunately it is only a matter of time
My 2.7RS motor was built on a 7R mag case and was resealed 2 times. Got it down to just on small drip but it always started out good until you get quite a few heat cycles then it starts somewhere.
If it stays dry yours would be the first 7R case I have ever seen or heard of that stayed dry.
My case was shuffle pinned and time certed and still had one small drip...no matter how much RTV was used to put the case back together.
good luck
Porsche Rescue
May 30 2006, 08:17 PM
I have always heard and believed that all 911 engines leak, it's only a matter of when and how much.
TROJANMAN
May 30 2006, 08:25 PM
QUOTE(fuch toy @ May 30 2006, 06:07 PM)
that sounds like a
Cap'n Krusty
May 30 2006, 08:29 PM
QUOTE(Dan (Almaden Valley) @ May 30 2006, 07:10 PM)
good luck
If you used conventional RTV, you'll NEVER keep it leak free. The Cap'n
bd1308
May 30 2006, 09:23 PM
RTV, at least the normal stuff does NOT like high temps at all....
b
turboman808
May 30 2006, 09:29 PM
And I read this after getting under my car and noticing a few leaks. One is the the valve cover and the other looks like the seal at the axle. Well not leaking bad
Eric_Shea
May 30 2006, 09:32 PM
A leak free 2.7, Is it possible?
No.
Mueller
May 30 2006, 09:39 PM
my bone stock original 70,000 mile 3.6 leaks oil
Dr Evil
May 30 2006, 09:42 PM
Bullshit! My engine doesn't leak any more oil since the last big leak I had.
Thats because it is out of oil and I have not refilled it
Sorry, couldn't resist.
J P Stein
May 30 2006, 10:01 PM
I'm sure it's possible.....but not at my house
Brando
May 30 2006, 10:31 PM
A brand-new non-used 2.7 turnkey still in original crating from Porsche with 0 miles will not leak.
At least, until you run it.
Aaron Cox
May 30 2006, 10:35 PM
they dont leak, if they dont have oil LOL
grantsfo
May 30 2006, 10:36 PM
leaking engine means it running. Damn I get a can of degrease and go to the car wash - its a lot cheaper than rebuilding an engine!
horizontally-opposed
May 30 2006, 11:37 PM
I've heard it said that, with God, all things are possible.
Some are just more likely than others.
Leak-free 2.7? I think that would fall in the latter category...
So.Cal.914
May 31 2006, 12:31 AM
They say "Harley's don't leak they mark their spot." I believe Porsche's have the same attitude, mine will get even if I don't treat it right.
BajaXJ92
May 31 2006, 06:50 AM
QUOTE(Headrage @ May 30 2006, 06:02 PM)
Now why would you want to get rid of the auto-undercarriage oiling system?
Its rust preventative!
Mark Henry
May 31 2006, 07:02 AM
QUOTE(fuch toy @ May 30 2006, 10:07 PM)
At least you're all honest...except one guy.
Tail-draggers never rust out on the tail end.
