QUOTE(rdauenhauer @ May 30 2006, 06:07 PM)
if youve ever noticed this cable & its plastic sheath run a torturious path to the latch.
Its restrained by 3 or 4 metal tabs to the tub (what do you call those?)
1st Q: did those have the blk plastic covers on them?
2ndQ: As the cable passes behind the headlight bucket it routes down and back up thru a smal hole in the front trunck support steel (73-74). Did that hole have a rubber Gromet OE?
Rich,
I'll answer for a '72. No plastic tab covers - seems these were mostly used to cover tabs that hold wiring harness in place (smart idea!). No grommet in support member (not so sure THAT was a good idea, though I don't see any rub marks after 34 years). I'd be surprised if they changed these themes for '73-74 models, but can't answer for them deifinitively.
Pat G
