messix
Jun 1 2006, 09:40 PM
there is no indent, no scribe, no cast in marks any where!
wtf!!!!!!!!! so i get it to tdc on the dizzy,[ i think] and push the car i little and i find about an inch of black on the impeller with a blade centered on it. did i find my 7.5% time mark?
so anyway i calked the blade and timed it on that. seems to run ok.
fire away!
Mueller
Jun 1 2006, 10:08 PM
there should be a mark on the flywheel as well for referance....
go check out the tech article @ Pelican on timing...they show a template that'll give you a good idea where to look and how to mark it....
messix
Jun 1 2006, 10:10 PM
QUOTE(Mueller @ Jun 1 2006, 09:08 PM)
yeah i did. not much help. no mark at tdc or 7.5%.
messix
Jun 1 2006, 10:15 PM
ok so i read the timing for carbs tech and it mentions that the marks are tucked up on the back of the impeller? now does that make sense?
Mueller
Jun 1 2006, 10:37 PM
QUOTE(messix @ Jun 1 2006, 09:10 PM)
that is why you
print out the template, to make the TDC and 7.5° mark
messix
Jun 1 2006, 10:50 PM
no worrries just got done. used a mirror and adjustable timing light. i had it at about 20%.
had to readjust idle also.
Porsche Rescue
Jun 2 2006, 07:35 AM
This might help for next time.
