The rubber on my gas pedal is split across the the backside by where it meets the floor, causing it to move fairly easy from side-to-side in addition to the direction that it's supposed to travel.
Is there a source for new ones, or should I post a WTB add in the classifieds?
Also on a somewhat related topic, the diaphragm inside my intake plenum (sp) sticks in the closed position making it tough to start from a dead stop very smoothly without keeping the clutch in and over reving the engine. I assume that the plenum itself is not exactly round anymore. Has anyone else encountred this problem? Can I use a hone to fix the plenum walls like you would with a cylinder or should I just look for a 'new'plenum? Would a 'new' plenum require a new gasket as well?
btw, the car is a '75 2.0.
Muchas gracias!
