QUOTE(jimtab @ Jun 3 2006, 08:51 PM)
Thanks all, that is about what I figured...Dan, I'm sure you're right I sure enjoyed the streets course at wcco5 last year, I don't think I'll be too fast, but I should be able to keep myself interested....so where does one get magnetic sheets?
You can order it in 12x12 and 12x24 sheets online. then you can get any good graphics shop to make you some contrasting vinyl numbers.
Comes in various colors.
Or you can spray paint with a stencil directly onto the magnetic sheet.
If I were going to do magnetics again, I would do the stencil and spray paint the numbers onto the mag sheet. easiest and cheapest way to do it if you make your own number grahphics on your computer, cut them out and use them as stencils.
Many graphics shops can do the whole job...magnetic and numbers but that will cost you $$$....much cheaper to do it yourself.
Actually years ago I went to a shop that sold magnetic sheets and bulk vinyl Made some stencils by making up 11"+ numbers on my computer, cut them out and then transferred them to thin cardboard and then used that as a stencil to cut out vinyl numbers. Used those magnetics for 12+ seasons. Still have them and they still work...used them on at least 7 different street/track cars.
