redshift
Jun 3 2006, 09:59 PM
http://www.914world.com/bbs2/index.php?showtopic=53106Just in case you missed it, I nailed this one, so it will stay at the top of the messages list until someone rents a truck, and comes to pick up my car.
I expect to have one of you lucky winners restore my car, for free.
Right now though, just make it run, and I won't have to get really mad.
Thanks,
stay!
I NAILED YOU! STOP IT!
redshift
Jun 3 2006, 10:22 PM
Nailed!
redshift
Jun 3 2006, 10:24 PM
It seems to be staying at the top now, so I will go away for a few minutes, and you guys figure it out.
I'll be back.
M
redshift
Jun 3 2006, 10:26 PM
Oh man.. it won't stay up there!
NoooooooO!!
redshift
Jun 3 2006, 10:34 PM
Look, we all know this isn't really nailed, I am just bumping it up to the top every thirty seconds..
I just need attention.
Hold me..
M
iamchappy
Jun 3 2006, 10:46 PM
Miles your not the only one with car that just sits there, some of us have gotten used to having a 914 for a garage or lawn ornament. 914's are to be seen not heard.
The non running 914 club membership is the majority not the minority.
Join the non running 914 club.
Member list starts add here:
1-Miles
2-Chappy
3-Qarl
4-Bork
5-Rick Alien
redshift
Jun 3 2006, 10:48 PM
FINALLY!
No! I can't! I have to make it move first, then I can park it!
It's only a mile away... I walked here! DAMNED CAR!
I am going to hotwire the pump... if I can figure out how to do that...
-blows up self- I hope the pump works!
M
Jun 3 2006, 10:53 PM
QUOTE(redshift @ Jun 3 2006, 09:48 PM)
if it's D-Jet, look at my thread about the carb pump jumper in the classics ...
just leave the FI connector on the relay board and add a ground wire on that pin..
that'll make your pump run as soon as you turn on the key ...
Andy
iamchappy
Jun 3 2006, 10:56 PM
Pull fuel pump relay out and jump terminals with a short wire until the pump starts, drive to a nice lawn ornament spot in the yard turn off car and disconnect jumper wire, go to bed...... Admire your ornament in the morning...
GWN7
Jun 3 2006, 10:59 PM
Push it home...there are no hills there and you have been putting on weight lately.....Oh I have a brick of 3 yr old white chedar...the kind that makes the hair stand up on your tounge
redshift
Jun 3 2006, 11:06 PM
The relay is good, what if my board went dumb?
The (black?) wire broke off the coil. Is that the tach? (I think)
Someone tried to help me in mostly dark.
I hate you Bruce, I should have you deported.
Thanks guys... (except for Bruce, of course)..
M
ThinAir
Jun 4 2006, 12:43 AM
I just had a similar experience. Fuel pump wouldn't do a thing. I tried a known good relay and it didn't change anything. I had power on both sides of the fuse on the relay board, but no power on the positive lead at the pump. Today I figured out that the relay board went bad on me. Fortunately I've got another that I could put in place to make sure.
If the relay board is bad, then I doubt that a jumper in place of the relay will do you any good. A couple of years ago I had a similar problem and I just disconnected the positive lead on the pump and ran a wire directly to the battery to get me home. When I got there I shut off the engine, then disconnected the wire.
redshift
Jun 4 2006, 12:53 AM
I just remembered that when I installed new relays, the pump wouldn't work for some reason, but it would work with a test relay I shimmed.. until I seated the new one a hundred times.
I think I know what it is... thanks guys.. I can't sleep... I hope my car is ok..
Come home, sweetie!
M
VegasRacer
Jun 4 2006, 05:40 AM
Maybe you're outta gas?
Operator error. Could have been worse, ya could have had a hot Swedish chic with ya and looked like a you know what .
Gint
Jun 4 2006, 08:05 AM
QUOTE(JPB @ Jun 4 2006, 06:15 AM)
You must still have that "bad gas" in the bottom of the tank and got down to that point was again. LOL
Sorry Miles...
un-nailed
Eric_Shea
Jun 4 2006, 09:48 AM
nailed...
I'm betting on the bad gas thing. Especially with that brick of aged cheddar. In fact, I'm certain Miles has bad gas.
redshift
Jun 4 2006, 09:50 AM
I can't have all the bad gas, what would you BAGS be full of...
oops.. that's right... sheep dip!
GWN7
Jun 4 2006, 11:06 AM
As I'm being deported anyways.......guess what I had for breckfast? A cake donut with cinnamon and sugar coating. Then I got in my Running 914 and drove to work. hahahahaha....
Aaron Cox
thats cold B
GWN7
Jun 4 2006, 11:19 AM
I live in a igloo what do you expect ?
Howard
Jun 4 2006, 11:24 AM
Miles, have you checked for this? Seems to be a rash of blue gloving going on.
redshift
Jun 4 2006, 11:23 PM
lol Howard!
Actually, I found a tube of KY in my fuel tank.
M
