I just finished installing 911SC struts (Bilsteins) in my '74. I am having a couple of problems:
1.) The steering seems twitchy. Very sensitive. I took great care in not messing with the alignment. Anyone had this when converting to 911 suspension?
2.) I am having trouble bleeding the brakes. I do not own a pressure bleeder so I had to rely on the wife. After bleeding all four corners about (3) times, (always starting with the farthest to the nearest), I get a semi firm pedal. If I pump the pedal it will come up, even with just one pump. What do I need to do?
3.) This is not a serious problem but may relate to number 1.) above: The steering is a lot easier now. It has a very light feel, like power steering.
4.) Does anyone know what Bilstein strut was commonly used, heavy duty or sport, from the factory on SC's? They feel a lot stiffer than the original BOGE that I replaced but not as stiff as I expected.
Thanks,
dave
