QUOTE(nycchef @ Jun 5 2006, 09:18 PM)
Jump the field lead to the D+ lead.
i am new at this. please explain above also i thought that if the regulator was bad it would overcharge the battery thanks
The regulator can fail to where there is no voltage applied to the field.
Ok.. back up... Alternator function 101.
In the early days of cars , there were generators. Generators have big permanent magnets that surround an armature. The armature spins, and the armature passes through the magnetic field to make DC electricity. They will function even if the battery is not present.
The alternator is more efficent. It uses a fixed set of windings in place of the permanent magnets, but it makes AC current. There are diodes to turn it back to DC current for the battery.
To make the alternator work, you have to apply power to the field. By raising and lowering the voltage to the field, you control the output level of the alternator. If you feed it 12v from the battery, it goes to "full field" or maximum output, which is about 18v.
The voltage regulator measures the voltage of the battery, and in response to that voltage level it increases or decreases the voltage to the field. The regulator can fail in two ways, one is completely open, where it never applies voltatage to the field, and completely closed, where it full fields the alternator.
Normally they fail open. By full fielding the alternator, you verify that it and all of wiring components work.
If you look at the diagram below... (diagram courtesy of Pelican Parts)...
You will see where the regulator plugs into the relay board. When the motor is running, use a jumper wire to connect D+ to DF. The alternator will go to full field if it is working. Most of the time you can hear it start to whine slightly under load. Don't run it too long like that or you risk boiling the battery acid out. (by too long I mean 30 minutes, 5 minutes or less is fine).
Hope that helps!
