WRX914
Jun 6 2006, 02:15 PM
I am trying to install the fog lamps on my car. Apparently, the car did not come with the lamps factory. Does anyone have a picture of the location of the mounting point of the front fog/driving lights?
Thanks all!
Keith
Eric_Shea
Jun 6 2006, 02:17 PM
It should have a 13mm bolt in the bulkhead where they mount.
WRX914
Jun 6 2006, 02:20 PM
I do have a stud in the front, but all that have looked at it say that it does not appear to be stock. When I bought the car, it had the 916 front/rear bumpers. The PO must have put them in. If I try to mount the lamps at the current stud location, the lamps do not fit in the grill openings of the bumper...
Thanks though!
KW
QUOTE(Eric_Shea @ Jun 6 2006, 01:17 PM)
WRX914
Jun 6 2006, 02:21 PM
I really could use pics...
So.Cal.914
My 72 did not come with foglights so I got a set and all I had to do is bolt them to
the existing holes(nut was in place) and plug them into the existing wires. The
switch was just as easy.
WRX914
Jun 6 2006, 02:22 PM
That is what I thought too... The only problem is there is no holes on my chassis!
QUOTE(So.Cal.914 @ Jun 6 2006, 01:21 PM)
Eric_Shea
Jun 6 2006, 02:35 PM
Someone's been creative... sorry, no pics from where I am. Someone can weigh in here with some. Should be plug and play as described.
So.Cal.914
Jun 6 2006, 02:53 PM
Sorry my tub is in riverside and my 72 is in one piece (how rare is that)
Dr Evil
Jun 6 2006, 03:05 PM
Do a search, I posted pics on this very topic a couple of months back that will answer your questions. The bolts do not seem to be intuitive in their location.
Also, it would be good if you could show us some pics when you get a chance.
Jun 6 2006, 03:08 PM
QUOTE(Dr Evil @ Jun 6 2006, 02:05 PM)
not only that, the cars that came without the foglights had a plastic cap covering the mounting holes/nut ...
they are there, trust me ...
Andy
PS: what year is your car? i'm asking because some of the early cars i have seen didn't have the wiring for the foglights in the main harness ...
markb
Jun 6 2006, 03:11 PM
Does this help?
WRX914
Jun 6 2006, 03:32 PM
That is exactly what I needed to see. Do you have a close up? I believe the PO must have welded the original holes shut. I have searched high and low, and there is no holes, no plug no nothing... It is a 73. Thanks Mark
QUOTE(markb @ Jun 6 2006, 02:11 PM)
Does this help?
So.Cal.914
Jun 6 2006, 03:35 PM
Those are the one's. You can see in this pic the outline of the foglight bracket
and a few nuts. Did I say that? I am in trouble again.
WRX914
Jun 6 2006, 03:36 PM
Thanks Andy,
I do trust ya, but they are not there!
The PO did install driving lights in the 916 front bumper, so I believe the wiring is ok. Thanks for the heads-up though...
QUOTE(SirAndy @ Jun 6 2006, 02:08 PM)
Andy
WRX914
Jun 6 2006, 03:37 PM
Hows about a close up pic?
Eric_Shea
Jun 6 2006, 03:48 PM
How did he mount the lights in the 916 bumper? 916 bumpers are made to handle stock lights in stock locations.
This is what I meant by "someone's been creative". They've either welded or mudded over the holes.
So.Cal.914
Jun 6 2006, 03:51 PM
Click to view attachmentThis was the best I could do in a pinch.
Jun 6 2006, 03:53 PM
QUOTE(Eric_Shea @ Jun 6 2006, 02:48 PM)
below is a pic of my 916 bumper with foglights, mounted in the *stock* location ...
i also attached a pic of the plastic cap that was used to plug the holes on cars that never had foglights (about the size of a quarter) ...
Andy
WRX914
Jun 6 2006, 03:54 PM
He was something if not "creative"
WRX914
Jun 6 2006, 03:55 PM
I will take a few pics tonight for all to see...
jgara962
Jun 6 2006, 06:26 PM
QUOTE(SirAndy @ Jun 6 2006, 02:53 PM)
Andy
Andy,
I just put pilot lights on my car with a 916 spoiler. Had to fab some brackets myself, but still can't quite seem to get the lights high enough to line up with the openings in the spoiler. Did you use stock brackets to mount your lights?
Cap'n Krusty
Jun 6 2006, 06:35 PM
We call those "8mm" bolts, not "13mm".. What you might call an "industry standard" terminology. The Cap'n
Jun 6 2006, 07:14 PM
QUOTE(Cap'n Krusty @ Jun 6 2006, 05:35 PM)
M8 with a head for a 13mm wrench ...
Andy
Jun 6 2006, 07:15 PM
QUOTE(jgara962 @ Jun 6 2006, 05:26 PM)
no, the brackets are not stock ...
Andy
boxstr
Jun 6 2006, 08:15 PM
Here is a pic of the blind nuts I use for mounting the CAMP 914 Pilot lites on a 914 that does no have the holes, normally a 75-76.
CCLINBLINDHOLE
Eric_Shea
Jun 6 2006, 09:29 PM
Shaaaaaaaaaad upppppppp
8mm bolt with a 13mm head... happy weinerschnitzel?
What about the thread pitch? Should we fill him in on that too????
mightyohm
Jun 6 2006, 10:10 PM
914-8
Jun 6 2006, 10:45 PM
Andy
Andy,
I was able to use the brackets that came with the pilot lights, and get them to line up in my 916 bumper, but I had to modify the brackets a bit. Basically, just elongate the slot in the bracket to give it a bit more reach.
Crazyhippy
Jun 6 2006, 11:07 PM
Here you go Keith...
There are advantages to having my car torn apart still....
Crazyhippy
Jun 6 2006, 11:08 PM
el Segundo
Crazyhippy
Jun 6 2006, 11:11 PM
magical # 3
I can take more if you need.
BJH
Crazyhippy
Jun 6 2006, 11:16 PM
el Segundo take 2...
Series9
Here's one:
WRX914
Jun 7 2006, 10:08 AM
Thanks BJ...
I think the PO must have grafted a 75-76 front end on my car. I see remenants of a wreck on the passenger fender well.
Thanks all, I am on it!
