blitZ
Jun 7 2006, 07:15 PM
I started a thread this morning regarding my car starting to clatter and running rough. This evening I put it up on jack stands and popped off the valve covers, everything looks fine. Started the engine and removed the plug wires until I found one which made no difference when I pulled it. I took out the plug and it appears the metal tab was pushed down on the electrode. What the heck is causing this? Is the piston smacking it? I gapped the plug and it runs fine. Any idea of the cause?
bd1308
Jun 7 2006, 07:19 PM
valve dropped...clattering isnt good at all.
is wrong with these engines...its like five in three months??
b
Mueller
Jun 7 2006, 07:38 PM
QUOTE(bd1308 @ Jun 7 2006, 06:19 PM)
b
let's see...the cars are 30 YEARS OLD and being bought and abused by people that think they are like Hondas?!?!?!?
Aaron Cox
Jun 7 2006, 07:40 PM
QUOTE(Mueller @ Jun 7 2006, 06:38 PM)
b
Mueller is having a BBQ,.... roasted britt for dinner LOL
Twystd1
Jun 7 2006, 07:49 PM
Maybe you just got lucky and ate a washer or something. And it passed out the exhaust. (happened to me a couple "O" times on V8s)
If you didn't eat a seat. You might have eaten something that was loose in the carbs or injection system. (check for loose induction stuff)
If the engine now runs fine. And doesn't make any nefarious noises.......
You are a very, very lucky man...... Indeed......
Twystd1
Mark Henry
Jun 7 2006, 07:51 PM
Over heating is the number one cause of dropped seats. I bet the cyl. fins and shrouding is just full of crap.
Do a valve adjustment before you run it again...one will be way out of whack....
bd1308
Jun 7 2006, 07:53 PM
Mike you havent met me, seen me or probably havent actually read into anything about me.
I drive a 1974 Porsche 914, with a 1.7L engine. I cruise, not race (why bother) and couldnt be happier.
If I wanted a Hondah, I woudl get one...
b
Mueller
Jun 7 2006, 07:58 PM
QUOTE(bd1308 @ Jun 7 2006, 06:53 PM)
b
that was not an attack on you, I'm just stating my opinion, which is based on some facts, the cars are 30 years old, motor failures are going to happen more and more.....there is nothing "wrong" with the motors except for age and use and some abuse....expect to see more engine failures both with the /4's and the /6's as time goes on....
bd1308
Jun 7 2006, 08:00 PM
Initially I thought it was a general statement...
we're cool.
I see this now, I guess alot of people just run the crap out of these engines 20+ years ago and now the OE engines are starting to fail?
Global Warming maybe?
b
blitZ
Jun 7 2006, 08:06 PM
Thanks for the input, I'll do an adjustment and see what happens. Is there anyway to determine if the valve seat is the culprit without removing the heads?
Mueller
Jun 7 2006, 08:08 PM
QUOTE(blitZ @ Jun 7 2006, 07:06 PM)
you
might be able to remove a valve cover and compare the height of the valves as you turn the motor over....
Mark Henry
Jun 7 2006, 08:15 PM
If one valve stem (valve adustment) is sitting way in (seat is out sitting crooked in it's bore) or is sitting way out (sunk into its bore) you have seat problems. Sometimes this doesn't work as the seat can be sitting in its bore but still be loose.
But the spark plug is a classic sign of seat problems.
SLITS
Jun 7 2006, 08:17 PM
There is prolly some ways:
1.) If the suspect valve is very loose, the seat could have cocked and is holding the valve open. This would case a misfire on that cylinder (won't build compression).
2.) If one valve is very tight, the seat is pulling into the head (under spring pressure). If it can be adjusted to tolerance, it should tighten up rather rapidly. Worst case scenerio is that you can't get any adjustment at all.
3.) I can't see with the configuration of the valves and combustion chamber how a valve could hit the spark plug. I could see the seat coming out and possibly hitting it, but then it would misfire on that cylinder.
4.) And what Muller said
Edit*** Are the electrodes bridged? 0.28 isn't all that much and a piece of carbon coming off the combustion chamber can bridge the electrode / possibly bend the tang.
jimtab
Jun 7 2006, 08:54 PM
QUOTE(bd1308 @ Jun 7 2006, 07:00 PM)
we're cool.
b
Personally, I blame the insurgency..................bastards........
blitZ
Jun 8 2006, 05:16 AM
I think I might pull the intake runner off on that side, might be able to get a peek at what's going on in the cylinder.
Thanks again.
pfierb
Jun 8 2006, 05:48 AM
QUOTE(bd1308 @ Jun 7 2006, 10:00 PM)
we're cool.
b
It's Al Gore's fault
Joe Ricard
Jun 8 2006, 09:29 AM
Nope, it's Britt's fault.
I GOT PROOF.............
Elliot_Cannon
Jun 8 2006, 09:38 AM
Could be a little piece of chop stick? Just a thought. Not necessarily a good one but a thought none the less.
Elliot (semi retired)
drewvw
Jun 8 2006, 09:42 AM
Britt, I'm with ya bud. I am a country cruiser myself. I'd love to vintage race, but who has the cash!!
I don't know how you guys do it.....
Dave_Darling
Jun 8 2006, 02:41 PM
A compression test will tell you if you have a dropped seat. I had one that popped in and out of the head (while I was driving!!) so a check of the valve clearances didn't really tell me anything. A compression test showed total leak-down (0 PSI!) on that one cylinder. The starter-cranking pattern was also very uneven; it sounded like "RR-RR-RR-..-RR-RR-RR-.."
Try a compression test. If you get one cylinder reading very low, you'll know you need to pull the heads.
--DD
blitZ
Jun 8 2006, 07:36 PM
Well, not so lucky after all. I adjusted the valves and started it in the garage, ran real smooth. Took it for a gentle spin, after a few minutes the clatter returned along with the missing. Guess I'll pop the heads off this weekend.
Twystd1
Jun 8 2006, 07:42 PM
LES,
I was hoping ya just got lucky...........
Let us know what ya find...
Giterdone..!!!
Cheers,
Twystd1
Dave_Darling
Jun 8 2006, 09:00 PM
Here, let me say this one more time: COMPRESSION CHECK. That should tell you if you have a dropping valve seat.
Re-check the valve adjustment; at least inspect the valve train. Who knows, it could just be a valve adjusting lug that you didn't tighten correctly...
--DD
blitZ
Jun 9 2006, 05:11 AM
QUOTE(Dave_Darling @ Jun 8 2006, 11:00 PM)
--DD
Will do, thanks Dave.
SLITS
Jun 9 2006, 06:36 AM
Or you could go to Harbor Freight Tools for a leakdown checker for $60. It should work at least once before taking a crap.
blitZ
Jun 9 2006, 07:11 AM
QUOTE(SLITS @ Jun 9 2006, 08:36 AM)
I was going to check out Northern tools, got one a few miles from home. Are they any good?
