QUOTE(Dan (Almaden Valley) @ Jun 12 2006, 10:40 PM)
Here are the two sections of the current GGR rules that cover fuel additives.
Playing devils advocate I believe the contradict each other.
Also our old rules specifically stated unless a modification was approved it wasn't approved. IE: you can only make the modifcations we say you can.
Now the rules do not state that....
They only say that if a modification is not specifically given a points value it is free.
As you can see from item (i) from the rules it only talks about non-oxygen bearing additives being limited to 10%.
It doesn't say anything about oxygen bearing additives such as Alcohol, Nitrous, or Nitro....
what you think?
i: Fuel: Any gasoline fuel is permitted. Additives (non-oxygen bearing) may be used as long as they do not constitute more than 10% of the fuel.
49)
Select this option if the engine has any of the following:
The engine has any type of fluid or gas injection other than gasoline.
The engine has any type of total loss injection device used to cool the engine intake system.
The engine has any type of fuel mixing system used to add alternative fuel to the gasoline.
I am going to have to disagree with Steve here. I think. I am assuming that Dan is quoting the rules so if he has paraphrased and I am misinterpreting based on that my apologies... I may also be misinterpreting Steve and if I am 1000 pardons my friend...
Section i above seems to deal with additives
by volume so in order for nitrous oxide to be illegal it would have to comprise greater than 10% of the fuel load by volume not percent of oxygen.
It seems that nitrous would be allowed if you look at section 49 since it could be pointed as a "...type of fluid or gas injection other than gasoline". And, "The engine has any type of fuel mixing system used to add alternative fuel to the gasoline"
This is potentially a good discussion but perhaps it needs its own thread?
Rob
