QUOTE(evan @ Jun 10 2006, 12:08 PM)
Hey Rand, when I first turn the key, i hear a humm / clicking sound. In checking the filter, should I disconnect the end opposite the filter away from fuel source?
evan
QUOTE(Rand @ Jun 10 2006, 10:24 AM)
What year and engine? Do you hear the fuel pump hum for a couple secs when you first turn the ignition on?
Yes, and sence you are going to pull that off put a piece of hose on it and run that
hose into a receptical and have someone turn on the key and check out the flow
it doesn't take much preasure for carbs. At least you will know that it is or isn't
your fuel pump.
