OK, here's something completely different-
'76 2.0 (originally)
euro 8.0 pistons
injectors rebuilt by Marin FI in Connecticut @ $25 each
early style SSI exhaust
stock D-jet
Isky 485129 cam, as follows-
advertised duration- 282
.050" (about 1.27 mm) duration- 228
lift- .450"
And yes, it's an HYDRAULIC cam (sorry Jake)
I have a smooth idle, with 13 inches Hg. It only has 300 miles on it though, so I may get a tiddle more....
Good mid-range torque, much better than before the rebuild (but then a lot more than the cam has changed). Still sorting it out, not exceeding 4000 RPM very often, but it seems to be coming on strong when I back off....
Probably will get an MPS adjustment when it's got 750 miles or so. Kind of nervous about it, but what the heck.
I am very glad I went hydraulic. The engine is quieter, and the valves self-adjust with wear and temperature. Afterall, that's the real point. I'm not lazy, but every performance car today (I think) has gone hydraulic for these very reasons....
Pictures- cam and crank in a test fit BEFORE I cleaned everything up. Also, oil pump mods to clear the cam bolts. Also, the car at about the time the cam pics were taken.... and today.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
