I'll start:
I awoke to a typical muggy Florida morning.....ok I won't tell the WHOLE story
Good things: Last week I pulled the engine and I seemed to have cured the oil leak that was flinging oil everywhere. And I found a valve that was too tight that was causing popping and farting. I had no problems with these two things yestersday.
Bad things: 1) I still have a hot start problem. After making one run I can shut it off on the grid and it will restart for the next run after about 15 minutes. But after the second run it will not restart and I have to sit in the car to keep it running as it won't idle by itself. The starter is turning over but it won't fire off. I need to check my timing. 2) I need to fab some sort of firewall behind my seat. After two runs the back of my aluminum seat is would make a nice frying pan. 3) I need to do an alinement job. I haven't checked it in awhile. 4) The car is still faster than I am, I should have done better.
I got four runs in before the rain it. So I packed up and went home. I'm taking July and August off. Too damn hot here.
Paul
