Use quality helm (sp?) joints. McMaster-Carr perhaps??
The ones that come with all the weber kits (CB, CIP1, etc.) are pure junk.
i think he is talking about the pieces that connect each butterfly to each other.....
for a SIX cylinder.
heim - (sp)
john rogers
Jun 12 2006, 01:29 PM
Try Pierce Manifolds, they have about the largest parts stock of anyone, although when I needed some float bowl plugs they were out as Gene Berg had bought all they had and used them up. I finally found the plugs at Motor Meister so try them second.
Mark Henry
Jun 12 2006, 01:31 PM
You would have to make new heavier rods to use my joints. Don't have a six here right now to see if they would work.
Eddie914
Jun 12 2006, 03:19 PM
Aaron,
You are correct. I am in need of the part that connects the two throttle shafts (spindles) together on each carb. The IDC3A series of carbs have a two piece throttle shaft - one for two barrels and another for just one barrel.
