QUOTE(Queenie @ Sep 30 2003, 04:53 PM)
When installing the pushrod tube seals, do they go in dry or do you use a dab of oil or some sort of sealing compound?
Thanks!
In Bruce Anderson's 911 book he writes...
"Lubricate the O-rings with a silicon paste or grease-type lubricant. Dow Corning 111 compound works well here.
The advantage of the silicon paste or grease over petroleum grease is that it will withstand very high temperatures and will not run off.
The reason for lubricating these O-rings is so they will reseal themselves anytime they have been disturbed by thermal expansion of the engine.
Do Not use silicon sealer in this application. These O-rings, by design, must be free to move and work to do their job correctly."
Bruce is talking about 911 oil return tubes, but 914 pushrod tubes work the same way.
