the senders are usually labeled 150 (10 bar) 80 (5 bar)
10 bar gauge, 10 bar sender.. 5 bar gauge, 5 bar sender....
lapuwali
Jun 12 2006, 02:51 PM
Should be 10 bar or 150psi. The fours used the 5 bar/80psi sender and gauge combo.
michelko
Jun 13 2006, 01:57 AM
Thanks for the replys. Only found a part number on the sender nothing like 5 or 10 bar. So i hooked up a 5 bar gauge and got very scary low readings with that gauge.
Will try to get a ten bar gauge and test it.
