I'd like to weigh and possibly balance my new set of pistons and cylinders this Sat.
anyone in SD have a digital scale that measures in grams???
no, seriously. Its for balancing my pistons.
Twystd1
Jun 12 2006, 08:16 PM
Can you come up to Costa Mesa?
Might be able to machine AND balance your entire assembly for cheap.
Pistons, crank, rods, piston/pins, flywheel and PP. On a Sunnen balancer complete with gram scale and the RIGHT tools to do the job.
My friend and machinist works on saturdays. I could ask him for the favor.
If interested..... Leave a message here or PM me for phone number.
brer
Jun 12 2006, 08:21 PM
WOW wouldn't that be great.
at the moment its only got down to the pistons, but was going to check the play on the flywheel thrust bearing this weekend to try and decide whether i should split the case and do the whole shebang while its out.
I'm kinda hoping the bottom end is still as solid as i was led to believe.
I'll get back to you after the weekend.
Thanks man!
Mark Henry
Jun 12 2006, 08:29 PM
My mail lady looks at me weird because I always have the package weight written on the box down to the gram. She doesn't even weigh my packages anymore.
brer
Jun 13 2006, 03:09 PM
extremely accurate bathroom scale maybe????
TimT
Jun 13 2006, 03:58 PM
I have and Ohaus triple beam scale from way back..
It is now reformed and helps balance engine parts
pete-stevers
Jun 13 2006, 04:05 PM
its not all bad.... you could use it for powder.... sorry that is in grains....
Brad Roberts
Jun 13 2006, 04:11 PM
Brer,
the shop has a triple beam you can use. Otherwise you will need to visit a paint store for a digital scale.
The local balance shop charges $100 for all rotating and reciprocating parts associated with an engine.
B
fitsbain
Jun 13 2006, 04:48 PM
I picked up a postal grade digital scale for $19 at Staples for weighing out model airplane parts for ultra light electrics. Measures down to .1 grams.
brer
Jun 13 2006, 08:30 PM
how fine is the triple beam?
postal scales are accurate correct? Fry's has one that i could use for a fair price.
