QUOTE(McMark @ Jun 12 2006, 11:32 PM)
Grab a 911 steering column. It will look the same as the 914/6 and bolt right up to your late model column brackets. If you really want to use the 914/6 stuff, you need to either make an adapter plate (
) or weld in an early engine mount.
IMHO, if I wanted to make a 914/6 look-a-like, I'd use an early car. The early cars are built on the same chassis as the 914/6, so more of the little details are correct. But you could do it with a 73.
BZZZTTT!!! Sorry..worng answer. BTDT!!
The 911 column uses a completley different mount than a 914. A 911 column will not bolt into ANY year 914.
You have to cut the mount off a 914 column, and cut the mounts off the 911 tube and combine the two to make it work.
911 Steering column (pet diagram.. I don't have a real picture)
Click to view attachmentFactory 914/6 column
See this link on how I did it...
Column conversion.
