i've marked the stock tower plate positions where the stock plates were. Now the 911 suspension is in and i'm dialing it in.
so far there appears to be zero toe-in at all 4 wheels and 3/8" of negative camber measured between the top and bottom of the front wheels. Rears are L- 9/16" R-3/4". More spacers for the rear I guess?
so the last thing i'm concerned with is caster.
how does one get it close? How is it measured?
Would you just use the previous plate markings as the alignment was great before?
All opinions will be greatly appreciated. Even Miles. =-)
