Mueller
Jun 13 2006, 12:19 PM
Getting another set of rims and tires for my car soon...currently have 17x7's on all four corners and will be getting 4 17x8's....the 8's are going in the back and the 7's in the front, this also means I'll have an extra pair of 7's and 8's with tires to use as spares or replacements later on down the road (hopefully a year or more)
(not that it matters much, 205 on the 7's and 245's on the 8's)
thanks
chilli
Jun 13 2006, 12:52 PM
No way am I an expert on this. But I keep my tires mounted with air and inside out of the sun. No special Majic treatment
Mike
turboman808
Jun 13 2006, 01:06 PM
I just shove em in the garage. Put the azeins on after 2 years and they still work fine. First autox the tires hard to get rid of the old rubber on top but then took like 2 runs and they were back to normal as far as I could tell.
rcrgrl
Jun 13 2006, 01:09 PM
wrap 'em in a black plastic garbage bag, tie it tight and keep em in the garage.
r_towle
Jun 13 2006, 02:10 PM
What ruins tires is ozone.
Ozone makes the rubber dry rot, and crack.
Put the tires on a pice of wood, not on the concrete...put each tire in a sealed plasitc bag (this kees out the ozone gas)
Keep them in a cool dark and shaded area...
Keep the temp stable...so the basement is a good place, versus the garage which fluxuates temp wise..
aside from that...good luck.
Rich
736conver
Jun 13 2006, 02:11 PM
Keep them away from electrical motors. Ozone breaks down the tire. Air them up with nitrogen to keep moisture away too.
I went to a corvair meeting once and this is what the goodyear tire guy suggested.
r_towle
Jun 13 2006, 02:13 PM
Please enlighten me.
Why electrical motors??? that is a new one for me, and I want to learn something today.
Rich
736conver
Jun 13 2006, 02:16 PM
QUOTE(r_towle @ Jun 13 2006, 03:13 PM)
Rich
Electical motors put out very high levels of ozone.
Jun 13 2006, 02:19 PM
QUOTE(r_towle @ Jun 13 2006, 01:13 PM)
the spark common in electrical motors creates ozone ...
Andy
r_towle
Jun 13 2006, 02:21 PM
cool, I thought it was a gas, only produced by aerosol....
Rich
Midtowner
Jun 13 2006, 02:26 PM
QUOTE(SirAndy @ Jun 13 2006, 01:19 PM)
Andy
I'lk keep this in mind next time I use my hair dryer, electric shaver, etc.
bondo
Jun 13 2006, 04:37 PM
Only brushed electric motors make continuous sparks.. Induction motors do not. Brushed motors are common in handheld drills (AC and DC), hair dryers, and small motored saws. The large motors you find on a compressor or a table saw are induction motors. If it has a starting capacitor, it's an induction motor. Most AC fans are aslo induction.
I don't think motors would produce enough ozone to worry about, unless run continuously.. in which case you'd be going through alot of brushes.
Those electrostatic air purifiers put out a whole bunch of ozone though..
swl
Jun 13 2006, 05:44 PM
QUOTE(r_towle @ Jun 13 2006, 12:21 PM)
Rich
<treehugger mode>
you were right Rich- it is a gas. O3
http://www.atmos.umd.edu/~owen/CHPI/IMAGES/ozonepro.htmlThe connection with aerosols is the the older propellants contained CFC's which depleted the ozone layer in the upper atmosphere. Ozone layer stops UV which causes skin cancer. More information than you ever wanted to know can be found at
http://www.atmos.umd.edu/~owen/CHPI/IMAGES/ozonepro.html</treehugger mode>
736conver
Jun 13 2006, 08:22 PM
Here's what goodyear says. Right from the website. Nothing like too much infomation
HOW TO STORE YOUR TIRES
The best place to store tires is a clean, cool, dry, sunless area away from strong air currents. Even though the rubber used to make tires is formulated to resist the effects of sunlight, ozone, and water, the life of a tire can be extended if exposure to these elements is minimized during storage.
Stack tires flat so that the bottom tire will maintain its shape
Wrap each tire with an opaque polyethylene covering to minimize the effects of oxygen and ozone. Most Goodyear retailers have storage bags made specifically for this purpose
If tires are being stored outdoors, they should be raised off the storage surface
If tires are stored while mounted on rims, they should be inflated to 10 psi
If they are put in storage during warm weather, the initial inflation pressure should be about 15 psi to offset the pressure drop during cold weather months
HOW NOT TO STORE YOUR TIRES
Don't store tires in an area that is wet, oily or greasy
Don't store tires where they are subjected to direct sunlight or extreme temperatures
Don't store tires near electric motors or other ozone-generating sources
Don't store tires on black asphalt or other heat-absorbent surfaces
Don't store tires on or adjacent to highly reflective surfaces such as sand or snow
Mueller
Jun 13 2006, 08:30 PM
QUOTE(736conver @ Jun 13 2006, 07:22 PM)
What the he// do they know about tires, they only have a blimp?, hahahhaha
thanks for the list....now to find that open space in my garage
