Jeff73
Jun 13 2006, 10:29 PM
I just purchased a 73' 914 and I have a problem. I am locked out of the car. I know I could probably call a locksmith and they could open it for me, but I don't want to spend 60 bucks to have them open a car that doesn't run right now. Can anyone help me get in my car. Is there an easy way to jimmy the lock?
Hammy
Jun 13 2006, 10:37 PM
Are your keys locked inside or what?
I left my keys in the seat once and there was enough room between the windows and the top targa seal to pull open the rear targa latches with a coat hanger. You can then prop up the rear of the targa top quite a bit for more room, but be careful not to break anything.
Then I used some coat hanger to get the keys.
Jeff73
Jun 13 2006, 10:42 PM
I think I can try that, we'll see. I just bought this thing yesterday and I am trying to start messing with it. Guy said it ran 1.5 years ago. Has some front end damage though. Paid 750 for it. Learning how to work on a Porsche.
Hammy
Jun 13 2006, 10:46 PM
QUOTE(Jeff73 @ Jun 13 2006, 09:42 PM)
It'll work. Just need to make as much room as possible by raising the rear of the roof. Hardest part for me was pulling the rear latches open. good luck....
highways
Jun 13 2006, 10:52 PM
You can also try someone elses keys. In highschool my buddy and I had different 914's.... and he was surprised one day when I started his up while his keys where still in his pocket. There's probably only about 5 major key patterns from the factory, and they're pretty simular. Just be very gentle if you're using random keys- don't wanna tweak your cylinder cause it probably wont be a perfect fit, but close enough. But yeah, I did the targa top hanger trick too. Sometimes you can push your window down a little to make a little gap to get started fishing.
Jeff73
Jun 13 2006, 10:54 PM
Thanks, I'll keep you posted.
Demick
Jun 13 2006, 10:59 PM
There's a lot more than 5 key combinations. But most 914 locks are so worn, that they can be fairly easily opened by similar keys or even just some strips of metal or plastic of about the right size. I've had to open my doors 3 or 4 times that way.
Demick
Jeff73
Jun 13 2006, 11:04 PM
The handle operates fine, I can put the key in it and it turns. But nothing. I can see it is locked on the inside, but it just doesn't want to open. I'll keep trying.
Hammy
Jun 13 2006, 11:08 PM
QUOTE(Jeff73 @ Jun 13 2006, 10:04 PM)
Sounds like maybe the plastic lever is broken to me.... Very common and easy to fix. Once you get the door open
Joe Bob
Jun 14 2006, 08:01 AM
Some are helped with a good shot of graphite in the lock.....btw, took me an hour last time I locked my keys in the car to get it open....my blonde girlfriend got real bored sittng in there with nothing to do...
DonTraver
Jun 14 2006, 08:09 AM
I've used a coat hanger to open the lock latch inside. Snake it in between the top and window, then work it down the back side of the window, helps if you have someone directing you.
Good Luck, Don
brant
Jun 14 2006, 08:34 AM
QUOTE(Jeff73 @ Jun 13 2006, 11:04 PM)
both doors are the same?
weird...
both broken at the same time?
I've used a coat hanger to pull the lock tab open before...
brant
Jun 14 2006, 10:06 AM
AAA ...
took the guy 30 seconds ...
Andy
effutuo101
Jun 14 2006, 12:27 PM
i found a file folder with a metal hanger on it i took out the metal and it slides between the door and glass easy. find the lock bar and pull up
bd1308
Jun 14 2006, 01:43 PM
I dont knwo what you all are pulling on...
i just push the tab, and it unlocks.
done it twice, once at work...
b
Jeff73
Jun 14 2006, 03:05 PM
Gonna try a few more things when I get home from work. We'll see how it goes.
Hammy
Jun 14 2006, 07:09 PM
QUOTE(bd1308 @ Jun 14 2006, 12:43 PM)
b
What tab
