Sparky
Jun 14 2006, 12:44 AM
Ok HVAC guru's, I have an oil burning forced hot air furnace, We plan on selling the house very soon so I dont want to spend the additional to add the central air stuff. Is there a way to wire up the furnace to run just in fan mode to ciruclate air? Currently it has a two wire thermostat hooked up.
Thoughts and suggestions appreciated!
My best,
Mike D.
crash914
Jun 14 2006, 05:28 AM
short answer is yes.
long answer is I don't know how to do it.
I know there is a relay from the t-stat to kick on the oil burner, you could use the cooling part from the t-stat wired into another relay to kick on the fan.
The way the current t-stat is wired it sends a signal to both the oil burner and to the fan. I can't remember if the fan is daisy chained from the burner. for what it is worth, sometimes the schematics are located inside the fan door and the cover of the oil burner...
Mark Henry
Jun 14 2006, 05:32 AM
Most of them have a switch on the furnace to do this, It should say "summer/winter".
blitZ
Jun 14 2006, 06:50 AM
This might work well if your duct work runs through your basement. If it runs through the attic, you'll probably be circulating hot air.
Sparky
Jun 14 2006, 07:51 AM
All the ducts are in the basement and feed up to each room. All pop the cover off the boiler once I wake up a bit more and check it out.
Mike D.
elwood-914
Jun 14 2006, 08:22 AM
Like Mark Henry said SUMMER SWITCH
Sparky
Jun 14 2006, 09:54 AM
Ok I opened it up and found... confusion. No schematic, on the outside of the furnace is a kill switch, on the inside is a rocker switch. Neither is labled but I do know the outside switch is the kill switch (watched the furnace guy turn it off to clean it). The furnace is an Olsen BCL-120 5.
Why am I so hesitant to turn off the inside rocker and see what happens? The wife isn't home... Seriously whats the worst that could happen. Oh wait that would be screwing up the furnace and having to replace it. Which would mean the end of my paint-the-teener fund account.
Help me save my paint fund!
Mike D.
Steve Thacker
Jun 14 2006, 10:57 AM
Information page with contact number. Just tell them the T-stat type. I'm sure they would have no problem helping you out
http://www.olsenhvac.com/Oh yea I forgot to add. If you have a two wire then you don't have the control for the fan only. There has to be a switch on the unit to put it in summer mode. The folks above should get you squared away.
cantley914
Jun 14 2006, 01:49 PM
There should be a grey rectangular box mounted on the front of your furnace with a white stick or button sticking out.
This is your manual/auto fan control.
Push on that white stic/button it will put your blower fan on the manual state. To stop it (put it back on auto mode) just pull back on it.
Most of those fan control are manufactured by and have the name Honeywell on them
By the way the rocker switch on the ceiling is the master kill switch for the furnace.
Good luck
Steph
guywan914
Jun 14 2006, 05:56 PM
Sparky, the fan is controlled by the limit switch on most furnaces. That would be the grey box with a temperature dial in it. Those settings control the blower on [med pointer] and blower off [lowest setting]. The high setting is the hi-limit.Some fan/limit controls do have the push or slide button that someone else referred to but not all, that button will give you fan operation as long as it is in that position.
your thermostat wires go to a control on the burner or in the furnace. If your control has the following terminals R,W,G,Y,C, your in luck. If you put a jumper or wire a switch from R to G you'll have fan operation. f you don't have either that control or the fan/limit control with the button yuo will need to add a relay. If you need I can supply you with one . Give me a pm if you have trouble.
