1bad914
Jun 15 2006, 05:26 AM
I just installed a new set of TTR's and I was just wondering about the amount of adjustment. I have not had the car aligned yet, but I did a "visual alignment" and there are almost no threads left for adjustment, is this normal?
I can't wait to drive the car, the front end is completely rebuilt, should be very tight, I also threw in a bump steer kit.
Brad Roberts
Jun 15 2006, 10:48 AM
Hi Randy,
Does the car have 911 struts or the stock 4cyl struts?
Did you take any pics during the install?
B
Joe Ricard
Jun 15 2006, 11:28 AM
Probably not going to need much. Where do the wheels point now?
get your jack stands and some string and ruler. you can get it pretty close. Toe in will give you more thread showing. toe out which should be done ONLY if you know why you are doing this still won't use up all the adjustment
Brando
Jun 15 2006, 11:54 AM
Hmm... With suspension stuffs, I'd definitely say take it to a shop that knows how to align Porsches. Get it as close as you can, drive safe, and get a 4-wheel alignment (if you haven't within the last year).
Porsche Rescue
Jun 15 2006, 03:54 PM
Did you use the spacers?
