adidas
Jun 15 2006, 12:15 PM
Hey Guys I have a 70-74 factory 3 port fuel pump. I tested it with 12 volts and it runs. I tested for fuel flow by taking the suction and return hoses and submerging them in a container of gas and routed the discharge hose to an empty container. When power is supplied to the pump it leaks around the black plastic electrical plug that the wiring harness plugs into and is putting out no fuel from the discharge hose. Is this repairable or did I route the hoses wrong. Thanks. Bill
drgchapman
Jun 15 2006, 12:18 PM
It's done.
Get ready to spend some $$$$. Iffin' you can find one.
sean_v8_914
Jun 15 2006, 12:29 PM
take it apart and fix it
dinomium
Jun 15 2006, 01:03 PM
just replace it and relocate it to the front trunk. New hi pressure pumps are around $150, you need 39psi iirc.
If you really want to stay OG, I have a three port on my shelf
