QUOTE(Brad Roberts @ Jun 16 2006, 08:21 AM)
I wonder if the Boxster shifter would work? They all operate by push/pull (duh)
The Boxter setup is nice. You could mount the base on the dash if you wanted.
B
I bought a Boxter shift tower and cables from a junk yard. The cables were too short to make it to the rear of the transaxle in the 914. So I used the tower, hung the Boxter cables on the wall and bought McMaster-Carr cables that were the correct length and adapted them. It worked nicely before, but for the tube car, I am going to make a new rear pivot that should work really well (hopefully).
Here is the shift tower with an aluminum angle attached to it that I then attached the cables to. Makes for a ton of adjustment to get the shifter where I want it in neutral left right sweep.
Click to view attachmentThe problem with these towers is that without reversing the direction of the fore/aft motion, the pattern would be upside down (the cable attachment is below the pivot point of the shift handle). So, you have to add a link in somewhere to reverse that direction, which is what I am going to redo for the new car.
It looks to me like the one driveability used has the attachment fore/aft ABOVE the pivot point. This would mean you wouldn't have to reverse the direction before going to the trans.
I like that I reverse the direction as it gives me an interface to change that ratio, therefore I can "choose" how tight I want the pattern to be simply by moving one cable closer/further from the pivot axis. Mucho nice frankly.
