I thought I would open another thread since the MPS was definitely bad. I believe I may have another problem, but had to rectify the MPS first.
Update - June 15th:
The MPS on my car was blown. I replaced it this evening (thanks Ron) with one that tested to spec. The car's performance improved (no backfire!), but it did not cure the hunting at low idle. Adjusting the idle screw did not affect the idle speed.
Next, I hooked up a vacuum gauge to the throttle body (did not tee it - just blocked off the hose going to the diagphram (retard side) of the distributor. I measured 13.5 inches of vacuum - so that is a little low. Need 15 inches - correct?
However, the car now idled and I could adjust the idle screw, which adjusted the speed to 950 without a problem. It stayed rock steady at 950. Connect the vacuum hose from the dizzy to the throttle body - the car low idle hunts/dies again. Removed and blocked off - 950 rpm.
I take the Mighty Vac this morning - start the car and pull 15Hg of vacuum on the diaphram. The car idles at 950rpm, but I notice there is leakdown to about 5 Hg within 60 seconds. Even after leakdown the car idles. Reconnect the vacuum hose from the throttle body to the retard side of the dizzy - car hunts/dies.
So - is the problem the dizzy or just the Vacuum Diagphram? I will recheck the timing to see if I set static timing correctly at TDC or the 7.5 BTDC mark. Timing was dead on - 27 deg BTDC - but I will double check. and Dwell at 48.
Question 1: How to test the diaphram? Pull 15HG and see if it holds it for x minutes?
Question 2: Does this sound more like a timing issuem than a fuel issue?
Looks like I still may have a small vacuum leak somewhere else, unless I am measuring it wrong.
So progress. The MPS needed replacing, but the idle is still the same - although no longer burning rich.
Thanks in advance.
Frank
