I'm trying to remove the outer half of my outboard CV joint from when it busted last weekend. I've got the shaft out, as well as the bearings and all 13 pieces of the inner cage, but I can't seem to break it loose from the hub. Since it's so tight right there, I can't really ger anything in there, such as a chisel, to work them loose. I don't have any sort of large prybar (lost my tire iron last year sometime...). Is that the reasonable thing to do, or will that damage anything? I do have all four CV bolts out on that side too. (None of those had washers, but the inboard ones did)
Thanks in advance!
