zen motorcycle
Jun 18 2006, 08:44 AM
I recently purchased a 73 2.0 and last night took it out for the first night drive. To my amusement the low beam headlights are not working. High beam and fogs are fine. When I fully depress for high beams both low and high come on. I have looked around and seen mention of both the headlight relay and the turn signal switch. I am still waiting on my haynes manual so can anybody point me in a direction for cleaning the turn signal switch? Other ideas are also welcome. I will be cleaning contacts just because today as well.
ejm
Jun 18 2006, 08:56 AM
Not sure what you mean by "fully depress". Pull the signal stalk towards you with the lights on and you should hear the hi/low beam relay click. The relay is a square one on top of the fuse panel. If the relay clicks it's not the switch.
rhodyguy
Jun 18 2006, 09:24 AM
unless the stock wiring has been altered, the fogs should only illuminate while the headlights are in low beam mode.
k
McMark
Jun 18 2006, 09:29 AM
Check the fuse panel first.
Kevin is right, if you had the fog light switch on, you might be seeing the fogs turn on when you depress the high/low switch.
zen motorcycle
Jun 18 2006, 10:31 AM
QUOTE(ejm @ Jun 18 2006, 09:56 AM)
AAAAAAAGGGGGGGHHHHHHHH
I have gremlins
Just went out to se if I heard it click between high and low and they are both working now. It is the stock wiring so fogs are not a concern. Could this malfunction if the relay is getting hot? Just looking for ideas now.
Thanks and much appreciated
zen motorcycle
Jun 18 2006, 11:26 PM
Well,
I either have a bad relay or faulty wiring/PO. I reversed the low and High beam connectors on the relay and everything is working well. Does anyone have a wiring diagram if the headlight switch? I still haven't been able to find one
TIA.
If this double posts sorry.
markb
Jun 19 2006, 12:01 AM
QUOTE(zen motorcycle @ Jun 18 2006, 10:26 PM)
Well,
TIA.
Check over on the Bird Board. There are wiring diagrams there.
Tobra
Jun 19 2006, 09:01 AM
sounds like a bad relay. The headlight relay is a squarish one on the fuse block, seems to me it was the one all the way to the R side
cobra94563
Jun 19 2006, 09:41 AM
I had the same, intermittent low beams - mine was the dimmer relay (I guess referred to as the headlight relay.)
http://www.pelicanparts.com/914/914_electrical_diagrams.htmLook at:
>>http://www.pelicanparts.com/914/parts/Electrical/914_electric_74B.jpg
>>http://www.pelicanparts.com/914/parts/Electrical/914_electric_74A.jpg
