*kennyd*914
Jun 18 2006, 06:29 PM
This morning as I started my car; she let out a backfire that blew off a vacuum hose. I returned the hose to the proper location, but the idle is now at 250-400rpm. Needless to say not the best. I tried adjusting and checking all hoses but nothing seems to work.
She runs great on the highway, getting there is the issue. Any thoughts? any one?
Joe Bob
Jun 18 2006, 06:37 PM
Probably a leak....split hose or something. Try LIGHTLY spraying carb cleaner or starter fluid at suspect areas. Idle changes and you've found the leak.
jim_hoyland
Jun 18 2006, 06:41 PM
If you' running a L-jet on a '74, and you had a backfire, it may be the AFM. I haven't had this happen to me, but I saw an AFM that had bent flapper that resulted from a backfire. Others may have more info--for sure, check your hoses again, the small ones can look ok, but have hidden flaws--ask me how I know.
*kennyd*914
Thanks Mike .... and for the car info as well.
*kennyd*914
Jun 18 2006, 06:42 PM
FI D-Jet is the set up.
Thack
Jun 18 2006, 07:55 PM
Low idle is a lean condition. I suspect your not getting enough fuel. Could be an air leak.
Joe Bob
Jun 18 2006, 07:57 PM
Hey Thack....Carrera side script on a 914?
Thack
Jun 18 2006, 08:33 PM
I bought it that way. I like it. One day I will paint it and it will be gone.
