obscurity
Jun 19 2006, 11:56 AM
Whats the trick? The relay comes out no problem but the socket seems to be a grommet through the metal in the trunk. Do I just push it out and replace it if it breaks or is there a better way?
dinomium
Jun 19 2006, 12:16 PM
spray the base with some tri-flow or WD40 first, then use a weatherstiping tool to gently pry on it. It looks like a crowbar end on a screwdriver handle. if the nub does snap, I think PP has replacements. You will have to solder (or use squeeze on) the new leads.
Why are you wanting to yank the socket, I am just curious...
obscurity
Jun 19 2006, 12:40 PM
I am trying to strip everything off the car prior to rust repair and repaint. The last repaint by PO left everything in the car and it just bugs me when the entire wiring harness is red
rhodyguy
Jun 19 2006, 02:51 PM
it pushes thru from the trunk side towards the side the motor is on. just start one point with a screwdriver and gently work it. ixnay on the wd40. when it's time to install, go to the drug store and buy a little bottle of glycerin to lube and help ease the socket back in.
k
