QUOTE(r_towle @ Jun 19 2006, 07:01 PM)
QUOTE(type47 @ Jun 19 2006, 09:58 PM)
i'm interested. i have one just like it. but like has been said; all you need is a multimeter and pbanders.com
As I have no manual, and have found only a little bit online so far...
This one looks like you can adjust the MPS...
That alone cannot be done with a multimeter....
rich
You can adjust the MPS with that? i doubt that, i played with a janbo which is almost identical to that last one posted and its just a 70's ohm meter and checks to see if wires and good. it does work well to see if trigger points are set right and fire injectors off.
to adjust the MPS you need a vac pump a Inductance/VOM and a bunch of parts and the right numbers to adjust them right.
