QUOTE(TROJANMAN @ Jun 20 2006, 09:13 AM)
stock lug head size on a 914 are 19mm (fuch, mahle, steel)
most vdubs are 17mm
i have vdub bolts in my 914 that are 17mm
the 38mm you refer to on your mahles should be the length, not the head size
All air cooled VWs had 19mm wrench size lug bolt heads, and all Vanagons did, too. Most water cooled VWs use the 17mm wrench size. The Cap'n
