I don't know where the air leak is, so I am trying to find it. No carb cleaner in the cabinet so grab a can of brake clean and spray it around on the hoses....
I am amazed at the fireball you can get from the dizzy when you spray brake clean on it...oh yes looked at the can, very flammable....go figure....
I still have not found my air leak....AAR is closed, idle screw all the way in. my O2 meter goes lean when the idle drops. Fuel issue? pressure is rock solid. I did drop the pressure during troubleshooting to see what happened, nothing. although with about 25 lbs, I am now getting a miss at 6000 rpm. TPS? my AFR is still around 13.6 or so
Throttle body is tight, vacuum hoses are new and tight....???where to look next??
:howdy:
