so, i got a NetScreen 100 firewall for someone that i'm helping out setting up their network.
the firewall is used and the seller did not have any passwords to access it.
no problem, i though, as NetScreen lists the password reset procedure on their website.
basically, they say there are 3 ways to reset the password:
1 - you know the existing password and change it (doh!)
2 - you use the firewalls serial number as username and password
3 - you use the "pinhole" microswitch to reset your configuration
unfortunately, none of the above works ...
1 - i don't know the current password.
2 - the serial number that is printed on the label doesn't work. their PDFs says the admin has the option to "disable" this feature, which they must have done.
3 - the "pinhole" reset button does not do anything. nada. zilch. it's supposed to give me feedback in the terminal and change LED colors when pressed, but nada. don't work.
now, i also read that "juniper trained technicians" can reset the settings/password to default using jumpers on the motherboard.
of course, you have to ship the thing to them and pay $$$ ...
so, anybody here know what to do? what jumpers to jump?
Andy
