I am running a set of Yokohama A0032R S compound tires on my stock 2.0 liter Fuchs. They are 205 50 15.
I have run one event on them and just for starters I ran 35psi all the way around. After my first run the pressure rise was dramatic and I brought them down to 35psi again. from there they stabilized and by the third run they were 35psi before and after the run.
I accidently left the pyrometer at home so no temperature data available for this first event. Ambient was about 85 degrees.
My settings are 2 degrees negative front and 2.5 negative rear.
What experiences have you guys had with these tires? What pressures have you run?
