krazykonrad
Jun 26 2006, 03:26 PM
I noticed that one of my exhaust bolts sheared off. Its the last one back on the passenger's side. It probably explains the rattling that I couldnt trace. Anyway, is this a serious problem? ANy clues to why this happened? Does this have anything to do with the oil leak in the picture?
Many thanks!
Konrad 72/4
Brad Roberts
Jun 26 2006, 03:29 PM
Is it sheared off or did it just fall out.
Typically they dont shear off unless somebody is trying to break them loose.
B
Allan
Jun 26 2006, 03:30 PM
It's bad because you'll have an exhaust leak. It can be repaired by either using an easy-out or drilled and heli-coiled.
It isn't what the oil leak is from...
TROJANMAN
Jun 26 2006, 03:35 PM
gint just fixed one of these. i am sure he will tell us how much fun it was.
krazykonrad
Jun 26 2006, 07:54 PM
I definetly wasnt twisted out by me. It just fell out one day. It may have been sheared before or it may somehow have sheared while it was in and then the end fell out I dont know. ????????
Anyway here's a picture of the bolt.
THanks again!
Konrad
Mueller
Jun 26 2006, 07:59 PM
there is no relationship between that and the oil...if left as is, you have a good chance of an exhaust leak that'll end up melting/burning the sealing surface and you'll be searching for a new cylinder head...
krazykonrad
Jun 26 2006, 08:02 PM
Sorry wrong pic!
Mueller
Jun 26 2006, 08:06 PM
that is broken...you are hosed
you might get lucky and have enough of the stud sticking out to grab, but it'll be tough...if attempted to drill out a broken stud twice, 1st time worked well...second time I screwed the pooch and the motor had to be dropped so that I could remove the head...
Hammy
Jun 26 2006, 08:17 PM
I never got this.
Can a stud just be JB welded back in and end of story?
ptravnic
Jun 26 2006, 08:36 PM
I second trying an ez-out. Go slow and it will work. I did this a couple years ago. Took a couple hours and a lot of patience but got another bolt up and in there and have no leaks since!
-pt
nebreitling
Jun 26 2006, 08:57 PM
yikes. how do you have it if it just fell out?
whatever you do, it's a major pita. get the car up high on jack stands, drop the exhaust (you'll probably strip/pull another couple studs in the process...), try an EZ out, reinstall new stud with some JB-Weld on the threads, rehang the exhaust with fresh copper gaskets and nuts. worst case scenario is having to pull that head.
please do wear safety goggles, as little bits of metal rust and oil coming into your eye can be a not-fun trip to the ER. drinking heavily does not make this job go more easily.
Mueller
Jun 26 2006, 11:43 PM
QUOTE(Hammy @ Jun 26 2006, 07:17 PM)
I never got this.
I seriously doubt it would work in that application....I guess you could try and get back to us
So.Cal.914
Jun 26 2006, 11:57 PM
Same one broke on mine, I think it was stress fracture. EZ out will work just take
your time don't try to back it out to fast. . When you drill out
the stud use spray cutting oil and do, as mentioned before wear safty glasses
there will be rust, metal shavings, oil and various other UFO's (unidentified falling
objects). Any questions PM me.
krazykonrad
Jun 27 2006, 12:13 PM
THanks for all the help! I think I'm going to let my local shop do the out drilling as I really dont want to f-up the head myself. More importantly I dont want to tell the Mrs. that I f-up up the head my self and I need to buy a new one.
Thanks again,
Konrad
