QUOTE(Brad Roberts @ Jun 26 2006, 03:55 PM)
901/915/930/G50 all have the same side to side distance between the flanges.
The early 911 axles are shorter than the 914 axles by .500 several people sell spacers for this.. but I have never ran them. The CV's have more then .750 in play. This means only .250 split between the two. You have seen them ran for several years now in a 914 with 355hp and 8K RPM (ha ha and person who doesnt really know how to "blip" throttle downshift).
If you are running early 911 drive flanges in the control arm... then the early 911 4 bolt 2 pin stub axles slide in right now. They just barely clear the control arm.
ok, let me re-phrase my question ...
i already got, outside to tranny:
911 hub that fits the 914 wheel bearing, 944 stub axle that fits the hub, 944 CV, modified 914 axle to fit the 944 CVs, 944 CV, 911(915) output flange to fit the 901
all of this fit's perfectly using the 901, correct length (because i'm using the 914 axle shaft), bigger CV's (944) etc.
now my question is: if the 914 has the same overall width from output flange to output flange, my whole axle should just bolt right up to the 915, as my setup is supposed to use 915 output flanges anyways ...
correct ????
Andy
