Great advice for the new guy
No... they're not the same.
Bleeders go up. Early cars with those banjos only have one bleeder and it belongs up top. Later cars have two bleeders but they're still different. The top bleeder is inset further than the bottom.
Those could "probably" be interchanged but...
Make sure the notches in the piston tops are facing the direction of the rotor as it comes through the caliper. They should be 20 degrees off the vertical pad line. If you put the left caliper on the right... you'll want to switch them back.
