I blame most of the problems with the 4 to 5 lug adapters on CHEAP ASS 914 owners that would buy the POS cast aluminum units from JC Whitney and CB Performance...I mean, what do you expect for $40 for a complete set???
I had a set on a parts car that I had to remove which had stripped nuts, I drilled out the studs with a cheap drill and cheap bits, the adapter studs cut like butter, thier hardness was nothing like the good quality bolts or studs Porsche uses
In the picture below, the smaller holes are 14mm, the larger holes are for the adapter to be bolted down and those are for the recess of the nuts. The hole at the 3 o'clock position is normally a long stud which goes into the hub, has nut on it to hold it to the hub and then it passes thru the wheel with another nut.
The holes at the 12 and 6 o'clock postion are too close to the new studs, it gets even worse when you add in the diameter of the stud head which is not shown.
People have run them on the street and auto-x, but those that ran auto-x probebly got lucky and didn't get failed at tech.
